Help my svp ?
Isabelle P. #15966
Posts: 832 ✭✭
in My Mobile
I only need 175 points to reach my next level.
What do I have to face to access it?
19
Here is some information
https://community.fizz.ca/questions/1826956-rewards-rewards#answer_4150668
And some points3 -
Thanks Marina for the nice explanation
Regards
Mo3 -
Points
1 point: Give a kudos to a user by clicking on the heart of an answer.
3 points: Reply to a question on the Fizz community.
5 points: Receive a kudos from a user that click on the heart of an answer to indicate that he/she likes it.
5 points: Reply to a question that was published less than 5 minutes ago.
10 points: Be the leader of the day.
50 points: Be the leader of the week.
50 points: Be active on the Fizz community during the month.
50 points: Be selected as the best answer.
To complete
Level
Level 1: You have acquired less than 1500 points.
Level 2: You have acquired more than 1500 points and less than 4500 points.
Level 3: You have acquired more than 4500 points and less than 9000 points.
Level 4: You have acquired more than 9000 points and less than 15 000 points.
Level 5: You have acquired more than 15 000 points and less than 22 500 points.
Level 6: You have acquired more than 22 500 points and less than 31 500 points.
Level 7: You have acquired more than 31 500 points and less than 42 000 points.
Level 8: You have acquired more than 42 000 points and less than 54 000 points.
Level 9: You have acquired more than 54 000 points and less than 67 500 points.
Level 10: You have acquired more than 67 500 points and less than ? points.
Level 11: To complete
To complete
Upgrades
Note: It will take effect at the start of your next payment cycle and it is valid for two years from the date you apply it to your plan. Based on your level, you have a limit of 1 (levels 1 and 2), 2 (levels 3 and 4) or 3 (level 5) slots for upgrades, so choose wisely.
100 Mo: You made it to level 1 and unlocked the 100 MB Mobile Data upgrade for your monthly plan that doesn't contain data. (For beta testers only.)
200 Mo: You made it to level 4 and unlocked the 200 MB Mobile Data upgrade for your monthly plan that doesn't contain data.
250 MB: You made it to level 1 and unlocked the 250 MB Mobile Data upgrade for your monthly plan.
300 MB: You made it to level 5 and unlocked the 300 MB Mobile Data upgrade for your monthly plan.
500 MB: You made it to level 2 and unlocked the 500 MB Mobile Data upgrade for your monthly plan.
Voicemail: You made it to level 3 and unlocked the Free Voicemail upgrade for your monthly plan.
Long distance calls: You made it to level 6 and unlocked the free long distance calls (in the country of your choice).
To complete
Perk
500 MB: You signed up during the launching period of Fizz.
To complete
Badges
Newbie: You joined the Fizz community.
Amigo: You added someone to your Fizz contacts for the first time.
Tching Tching: You added some money in your wallet for the first time.
Touriste: To complete
Sundae: To complete
Chasseur: You referred 1 new member.
Heros: You gifted data to 1 friend.
Dinosaure: You are here since 1 month.5 -
Just stay present on the hub giving giving good answers and you will get it soon3
I just gave you a kudo (5 pts) ^-^
You'll get there soon don't worry!
Good luck!2
