How do i receive /send mms images on my LG G6?
I cannot receive or send.images on my Lg g6 phone..I have plenty of data and used the APN settings given...please help..i don't want to use the Google MMS app as well..any help?
  • TheDean
    TheDean Posts: 45 ✭✭
    If it's working using Google MMS, but not with the stock LG MMS app on the same phone, perhaps you should raise the  question at an LG forum.
    My daughter's phone (not an LG) had problems with MMS.  After manually adding the APN things started working.
  • Chris C. #7549
    Chris C. #7549 Posts: 16 ✭✭
    Manually create APN? That's what i did in APN settiings that Fizz asked
    APN: mobile.bm
    MMSC: http://mms.mobile.bm
    MMS proxy: mmsproxy.mobile.bm
    MMS port: 80
    APN type: default,mms,supl
  • Franfizz
    Franfizz Posts: 9 ✭✭
    Use "signal"!
  • Chris C. #7549
    Whats signal?
  • Yelena
    Yelena Posts: 1,861 ✭✭
    Here is a similar topic. Maybe you'll find something useful there -
    https://community.fizz.ca/questions/2018368-unable-send-images-using-g5-g6-used-work
  • Chris C. #7549
    I deleted Google mms app..configured my stock app. MMSrebooted and did factory reset...no luck
  • Chris C. #7549
    Mike Posts: 20,756 ✭✭
    Can you try to create the two manualy, one for data and one for MMS,
    If the SMS sent from FIZZ (this is the link) does not help you out.
    You can try to configure the APN manually. Here the full configuration
    For internet
    APN: mobile.bm
    Proxy: Not set
    Port: Not set
    Username: Not set
    Password: Not set
    Server: Not set
    MMSC: Not set
    MMS proxy: Not set
    MMS port: Not set
    MCC: 302
    MNC: 500
    Authentification type: Not set
    APN type: default
    APN protocol: IPv4
    APN roaming protocol: IPv4
    Enable/disable APN: checked
    Bearer: Unspecified
    Mobile virtual network operator type: GID
    Mobile virtual network operator value: 55
    For the MMS
    APN: mobile.bm
    Proxy: Not set
    Port: Not set
    Username: Not set
    Password: Not set
    Server: Not set
    MMS port: 80
    MCC: 302
    MNC: 500
    APN type: mms
    APN protocol: IPv4
    Bearer: LTE
  • Chris C. #7549
    How do i create 2 APN.? Which one do i use as default and my APN settings go only until APN roaming protocol line
    Fizzy Posts: 10,932 ✭✭
    Use 3 dots on upper right side of screen.
    Edit current APN to remove MMS, etc. Save it
    Add another APN for MMS.
  • Chris C. #7549
    I separated the 2 (please above posts) ..is this what you are referring to..which one do i check as default and are APN settings entered correct?
    It seems ok, the default is the one for internet.
    Reboot the phone and try to send a mms to yourself
  • Chris C. #7549
    Sending text works..browsing data internet works..but no mms..cant send or receive pics
    Edit your default APN, remove MMS port "80". Reboot phone.
    If problem persists, try resending the APN parameters from your Fizz account to your phone.
  • Chris C. #7549
    Removed 80 from port on default and rebooted..no luck.. It gives me error when try sending APN parameters...do i have to delere all my set APNs before doing thiis?
    I believe that you will be better of contacting the support
    CHAT
    Go to this page https://fizz.ca/en/contact-us, if you are not connect login
    Wait 15 seconds for the bubble icon to appear at the bottom right of the browser and click on the icon to chat with support. Try a different browser if you have issues getting the bubble to appear.
    FACEBOOK
    Your can also send a message via facebook messanger
    https://facebook.com/fizzca and click send a message (this is a bit slower)
    CONTACT FORM
    You can also fill a contact form from your account
    Once logged in, from the account panel go to My Profile -> Contact Form (the subject are limited) and fill out the form and someone will email you back.
    I believe that you will be better to contact the support
    CHAT
    Go to this page https://fizz.ca/en/faq/resolving-issues, if you are not connect login
    FACEBOOK
    CONTACT FORM
    If website is giving error, try deleting your browser cache. Try again with incognito mode or with other browsers on your computer.
    Sure you can delete your existing APNs and start again.
    You can contact Fizz customer support as well, but I think they will repeat some of the info already offered here.
  • Stéphane B. 10644
    Stéphane B. 10644 Posts: 786 ✭✭
    Make sure your phone is compatible with Fizz network https://willmyphonework.net/
    and that your APN is configured properly.
    Good luck
