Unanswered question
Do you want the solution to send PERK despite the bug of adding contacts?
Hello everyone, I did the experiment this morning and it works. I share it with you now.
Want to send gifts but it's not possible since the person is not in your contact list? Simple. Send him an invitation: "Invite friends". You send him an invitation to his email and WoW, his email is now in your contact list. Then you can send as many perks as you want! Just ask for the person's email as a private message.
If you like my solution, I like your kudos since I want to go to level 5 to have the 3rd box!
Thank you and generous hearts, you can give your FIZZ Perks !!!
Niceee thank you! There's a Kudo!
I guess we still need base perks on our contract to make it work right? And we can't exceed the number of data we have into our contract as a gift right?
Have a great day! :)
Fizzy
Fizzy
Fizzy
Level
5000 / 5000
Thanks Luc! This can be a good fix while waiting for permanent fix. However keep in mind that by doing this, you will be sharing more info about your email with Fizz and other users.
Hi Luc.
I manage to add in my list you and Camille, but ANY person from my list can't be granted with ANY gift. I had some persons from long time there, When I select one person (ANY) a red error appear saying "_shortcode.SOURCE_PRODUCT_IS_NOT_FOUND".
[Possible because I have only perks to give, and all my other data is rolled over. Probably Source may be monthly data, which is not to be found...]
Sorry.
IMO Fizz do that on purpose. I think Fizz regret that it gave us the 4GB Christmas gifts, and now make for us impossible to pass unused perks from one another, I mean to users in need, just till all perks will be expired. They will fix the problem just after...
Mario_D
Mario_D
Mario_D
Level
2
953 / 2000
Kudos to Luc, smart find but Fizz forces me to use Outlook to send an email and that is not the email service I'm using with Fizz so no dice for me.
@Mihai, Yes, yesterday another user trying to send me data and not perks and he had the same error. Really weird since I received a 500mb perk yesterday and 500mb of data from another user. I made the post of this error but no clear explanation. Does @Fizzy have an explanation?
here the post in french: https://communaute.fizz.ca/questions/2600975-shortcode-so...
LemonHead
LemonHead
LemonHead
Level
3
3720 / 5000
Here's a kudo. Thx for the info!
@Luc I found the explanation: that is because I tried to gift data starting from My Plans / Gift Your Data.
The good way is to go to perks and activate/gave as gift the chosen perk, as I found in the end, and I manage to send you 1Gb data perk.
Kimberley
Kimberley
Kimberley
Level
A great workaround, thank you, it worked for me.
Steve
Steve
Steve
Level
Thanks for the workaround Kudos for you!
