Is there a way to disable the indicator lights on the modem? I live in a studio apartment and the modem lights are way too bright when I am trying to sleep. I have to keep the modem turned on for a few smart devices.
Sorry you cannot turn off the front lights.
You might try covering the lights but be careful not to block any of the vents (as the modem will heat up).
I'm with you on that! I can't sleep with these lights... I just cover them with a little sticker.
Kyle,
Sorry, it's not possible.
Mélissa has the best suggestion; cover it with a little stricker.
Sorry not possible, but maybe you can cover it with a piece of fabric?
I covered mine with thick tape, it works well!
BEST FEATURE REQUEST EVER. Seriously, having Michael J. Fox hold glow sticks in the corner of my apartment would be less distracting.
