Hi anyone has issues to pairing your smart bulbs under 2.4g wifi?
My smart bulbs are from a brand Nooie, and I cannot pair them under Fizz wifi.
Thanks for the help
Hi Yilin
Try to disable the band steering this can help
1. Log in at: 192.168.0.1 from the web browser of any device.
Username: cusadmin
1- Click on this link: https://fizz.ca/en/faq/none-my-devices-can-access-interne...
I never had any problems with pairing them. You can only try a reset
Hi Yilin
By default, the Fizz modem comes dual band frequencies with band steering enabled.
As mentioned, once you turn off band steering or disable 5 GHz WiFi, you'll be able to pair your smart bulbs directly to the 2.4 GHz WiFi (using the unique SSID).
Yilin,
Like StefanM's answer,
Try to do a reset of your modem can help.
Mine paired and are working well. Maybe try to reset your modem and/or to disable the 5 GHz.
