Where can I check a Fizz coverage map with more details like 3G/Hspa/Lte/Lte+ ?
The Fizz map coverage is really simple and with no details like 3G,HSPA,LTE,LTE+......
Can we use Videotron coverage map also for Fizz ?
Has FIZZ access to all Videotron BTS/MSC ?
The best would be to update that map with Fizz coverage in detail...or just say watch Videotron map here.
Did you find this useful ?
No (0)
Yes (0)
Fizzy
Fizzy
Fizzy
Level
5000 / 5000
You can see all the cell tower locations and details here:
https://www.ertyu.org/steven_nikkel/cancellsites.html
You can try the Videotron map as well. Both Fizz and Videotron companies are owned by Quebecor. So yes they are sharing their network resources.
Gabriele
Gabriele
Gabriele
Level
3
2089 / 5000
Hi Cristi, you are right, the Videotron map should work as Fizz use the same network.
vanigh
vanigh
vanigh
Level
3
2860 / 5000
The coverage map provided by Fizzy is well documented, it shows where each cell tower is located along with the frequency.
