Wi-Fi range. Is it normal that my Wifi is so slow?
Hello
My internet is extremely slow in my bedroom and office. It was fine for months but now is not. I communicated with the support, but they told me to maybe buy an Wi-Fi booster. I live in a one floor less than 700square foot two bedroom appartement... is it normal that suddenly it stopped working fine?
If I were living is a big house I would understand, but it is a small/medium size apartment.
11
Best Answer
Hi Andre
Did you try to reboot the modem?
It can also that the signal is weak
Try to disable the band steering this can help
1. Log in at: 192.168.0.1 from the web browser of any device.
Username: cusadmin
Also try to change channel
A series of channels are available on each frequency (2.4 and 5 GHz) of your Wi-Fi modem. Interference can have an impact on these channels.
Manually changing the channels used for your Wi-Fi connection can improve your modem’s signal.
You can download an application for your phone, in order to see the WiFi signal around you.
Look for a Wifi Analyser to see which channel has the weakest signal and set that channel to your modem
Wireless → General Settings → 5 GHz → Wireless channel
And also for the 2,4Ghz
Wireless → General Settings → 2.4 GHz → Wireless channel
Source: https://fizz.ca/en/faq/my-wi-fi-network-cutting-how-do-i-fix-it
1- Click on this link: https://fizz.ca/en/faq/none-my-devices-can-access-internet-wi-fi-or-using-cable-how-do-i-fix-it
3- Click on it, and select chat if available, or any other option7
