the speed very weak and unstable and cut off many time some time the speed is 60 mega after 5 minutes be just 1-2 mega?
Is the Wifi Internet working with the other devices?
Did you try to forget the WIFI and associate the wifi again?
Did you try to reboot the modem?
It can also that the signal is weak
Try to disable the band steering this can help
1. Log in at: 192.168.0.1 from the web browser of any device.
Username: cusadmin
Also try to change channel
A series of channels are available on each frequency (2.4 and 5 GHz) of your Wi-Fi modem. Interference can have an impact on these channels.
Manually changing the channels used for your Wi-Fi connection can improve your modem’s signal.
Wireless → General Settings → 5 GHz → Wireless channel
And also for the 2,4Ghz
Wireless → General Settings → 2.4 GHz → Wireless channel
Source: https://fizz.ca/en/faq/my-wi-fi-network-cutting-how-do-i-...
1- Click on this link: https://fizz.ca/en/faq/none-my-devices-can-access-interne...
Try to follow Mike's troubleshooting tips. I f they don't work, please contact support. Also consider using the Fizz Modem (CODA) in bridge mode with a separate router. Coda modems are notoriously unstable
Hi Alaa,
Have you tried connecting to internet with an network cable instead of the wifi to see if the speed is good? This way we'd know if it's the Fizz modem or the internet connection that has a problem.
You could also do a speedtest: https://www.speedtest.net/
