Final step (confirming the tech appointment) does endless charging icon
I'm trying to buy a plan and schedule the appointment, while doing the final steps on the webpage,(and confirming the details), the Fizz logo just does an endless loop. Also, some webpages before were a bit glitchy, had to refresh a lot to see it properly.
Does the website experience some troubles? I tested multiple browsers and os, pretty much the same everywhere.
Thanks.
Hi Louis
Sorry you are experiencing difficulty while signing up.
Before retrying, please check your credit card account to be sure the transaction did not actually go through.
You can try clearing your browser cache and open a new tab in private mode.
Or if there is a temporary issue with the site, you can try again tomorrow.
If you need to contact Fizz, you can chat with customer support as follows:
3- Open a Fizz help page like this one: https://fizz.ca/en/faq/how-do-i-subscribe-to-fizz-home-in...
BTW this is a good time to join Fizz as they are giving $50 bonus credit to new customers.
If you need a referral code, there is a list here:
https://community.fizz.ca/questions/2198337-place-referral-codes
You can choose mine or the code of someone who has helped you. =)
To be transparent, both parties will receive the bonus credit once you have paid your second bill.
p.s. Glad it worked! Probably there was no more availability for the first date and time.
Did you find this useful ?
No (0)
Yes (0)
MichelP
MichelP
MichelP
Level
5000 / 5000
Louis,
Thank you for your answer and you have solved yourself the difficulty to fix the appointment with the technician for your installation of internet.
Domenic
Domenic
Domenic
Level
Hi this happened to me before, under the exact same circumstances. Regardless of which browser I tried. The Fizz team was super helpful. Under the "Help" tab, then contact us, I chatted with their team. It was explained to me that once in a while the situation that you mentioned can occur. They got back to me under 48 hours and everything was solved! Appointment booked too! You can even chat with Fizz on their Facebook page. https://www.facebook.com/fizzca/
StefanM
StefanM
StefanM
Level
5000 / 5000
Usually the Fizz Support Team is very helpful in this regard and they can schedule an appointment for you :)
