Wifi seems to be connected and working. Once every 60 sec, a website can ben updated but overall, it’s like i have no connection at all? It doesn’t work
Hello Berk,
Apologies for the encountered issue.
I have verified your modem's signals and everything appears to be fine regarding it's functionality, nor there are any confirmed issues with the network grid in your area which can affect you. Regarding the wi-fi connectivity, everything seems to be fine in there as well, except the connection of your iPhone, for which our tool suggests that you turn off the wi-fi function for 30 seconds and then re-enable to test.
A few more tips can be found here:
https://fizz.ca/en/faq/my-wi-fi-network-cutting-how-do-i-...
If the issue still persists, please test out through a cable connected device as well.
Have a good day.
Catalin
Hi Berk,
If your new billing cycle was due in this days, you should also check the transaction history to validate that the payment was processed.
Check the led status. If one of the 2 arrows is off or flashing this means that you have a problem with the signal from the coaxial cable, can be a problem with in your sector. Turn off the modem, disconnect the coaxiale cable, waith 2 minutes, connect the coaxial cable, reconnect the power cable, wait 2 minutes and try to connect. If this does not help it can be a problem in your sector.
Are you connected to the modem by wifi or ethernet cable? Does the problem affect both?
This guide can help you out: https://fizz.ca/en/faq/none-my-devices-can-access-interne...
You can also contact customer support by chat, from 8 AM to 9 PM every day:
3- Click on this link: https://fizz.ca/en/faq/none-my-devices-can-access-interne...
Follow mike's answer..
Hi Berk,
If it still does not work, do not hesitate to contact Fizz support for help.
First, log into your Fizz account.
Make your way to the Solution Hub.
On the help page pertaining to your issue, click on the chat bubble located in the lower right-hand corner.
The chat service is available every day from 8 a.m. to 9 p.m. EST. The chat bubble won’t appear outside of these business hours.
try wired connection to compare whit wifi
