What is the procedure if move too another appartment, do I keep my modem and plug it on the wall and
simon H. #35497
Posts: 1 ✭✭
in Internet
What is the procedure if move too another appartment, do I keep my modem and plug it on the wall and its good to go ?
6
Hi Simon
Yes you need to plan a move and bring your modem
https://fizz.ca/en/faq/im-moving-how-do-i-change-my-address-my-home-internet-service
1- Log into your Fizz account and click on My plans.
2-Select your internet plan and click on Manage my plan.
3-Click on Moving my service.
4- Follow the instructions. You’ll have to:
-validate the availability of the Fizz Home Internet service at your new address;
- confirm your new plan;
- schedule your installation appointment at your new address;
- confirm your deactivation date at your current address.
Don’t forget to bring your Fizz Wi-Fi modem with you at your new service address.2 -
Yes, you bring your modem to your new apartment. Also you have to schedule an appointment with a technician. He will check the signal at your new place and if it's necessary he will connect your new place by cable.3
Hi Simon
Please consult the moving instructions from Fizz:
On moving day, you will need to unplug the modem and bring it with you.
If the new apartment already has cable internet, you will likely be able to use your Fizz modem right away. In this case, you should contact Fizz support to confirm the status of your plan during the transition.
You can contact customer support by chat, from 8 AM to 9 PM every day:
3- Click on this link: https://fizz.ca/en/faq/im-moving-how-do-i-change-my-address-my-home-internet-service
4- The green chat bubble should appear after a few seconds in the bottom right corner.3
