do the sims work with old phones?
Joseph M. 73515
Joseph M. 73515 Posts: 3 ✭✭
I have an old phone i would like to use, it uses the big standard sim card, will it be compatible?
Thanks
    Fizzy Posts: 10,935 ✭✭
    Hi Joseph
    Which phone is it? Sounds like it won't be compatible.
    Here is the guide from Fizz on compatible phones:https://fizz.ca/en/faq/compatible-devices
  • Danny M. #31189
    Danny M. #31189 Posts: 378 ✭✭
    Big sim is okay, however the phone might not work: check Fizzy's link!
  • Samuel C. 73358
    Samuel C. 73358 Posts: 37 ✭✭
    There are three different sizes you can chose from when you receive your sim, the sim will most probably fit but your phone might not be compatible with the fizz network. For iPhones, the 5s is the oldest you can use. For androids the phones sold in the past 5 years are compatible. Please inform me of which one you have.
    Thanks
  • Joseph M. 73515
    i have an iphone 4s so probably wont work.
