Koodo not able to port from Fizz
Andy_ref_87JI5
Posts: 6 ✭✭
Unfortunately I am needing to leave fizz. I am trying to port my number from Fizz to Koodo but the Koodo is saying my account number isn't valid. I gave them my client ID which seems to be the same as my account number with my phone. I will be reaching out to Fizz support tomorrow but I'm looking for other suggestions.
23
Hi Andrew
Sorry to see you go. To get your account number, go to My Plans >> Manage Plan
You will see it right under your phone number.
Account ID : (account number is 8 digits)13 -
Hi Andrew,
Instead using the account number, did you try with the IMEI?
Dial *#06# on your phone to get your 15-digit IMEI number.
For the account number, I believe that sometime provider expect a longer account id and you should add zero in the front.12 -
hope that will be ok for you10
