I was charged for their device even though I returned it
Shazzad
Posts: 2 ✭✭
So I left FIZZ internet on June when I left Montreal and came back to my home country. So I had to return their router via Canada Post which I did. Even though I returned it they charged me frigging $169 even though I returned the router completely new. What should I do in this case? This is completely unethical!!
21
you must contact the support with the proof
2- Click on this link: https://fizz.ca/en/faq/how-do-i-return-my-wi-fi-modem
3- The green chat bubble should appear after a few seconds in the bottom right corner.10 -
You need to contact the support, with post Canada you probably have a tracking number12
In this case, the easy solution is simply to contact the customer service. It is probably just a mistake in the system that can be easily solved with them. But you definitely need to speak to an agent for this problem to be resolved.
Cheers12 -
I would contact support for this.7
contact fizz customer service3
Shazzad,
Unfortunately,
You need to contact the Fizz customer service by chat and give them (the receipt) the proof of the return of the modem by post Canada.
With this information, they will cancel thoses charges for the modem.3 -
Hey Shazzad. Did you contact Fizz with the receipt from Post Canada? Did Fizz refund you? Thanks for sharing!6
