Why won't Fizz let you use your data during an emergency?
Francois D. 65372
Posts: 3 ✭✭
in My Mobile
13
Can you explain?1
When I turn on my data, I have no access to the internet. I have Fizz (not Fizz Ext) and i set up the APN configurations. seems like there is no issue except the fact I can't use internet1
Did you already verify the APN’s configuration?
Do you have Fizz or Fizz Ext?
With Fizz Ext you need to enable the data roaming1 -
Fizz has no idea when you have emergency.3
