Why my phone uses only 3G networking. I found the answer
I am using FIzz, My wife is using also Fizz. I was using 3giga mobile data plan, and my wife has been using 6giga plan. I could use LTE.
I don't remember when I changed 3giga to 1giga.. but I could only use 3G.
Yes... that is not the problem of phone neither configuration. The problem is because you are using cheap plan. My wife keeps using LTE
Fizz never mentioned about this.
12
On my knowledge, does not exist a 3GB plan, I have friend with a 1GB and one without data (he is using only bonus) and they are able to have the LTE.
Did you try to put the SIM card on your wife phone?6 -
Jyong did you reach Fizz? We are customers and can’t answer your question:(6
You need to contact Fizz support6
Wrong. I have 2 gig plan and I have LTE most of the time.
Btw, there is no 3 gig plan, only 2 or 4.5 -
Sorry.. it is not because of the plan..I put my sim to my wife's phoine. It worked with LTE,
but I am sure I was using LTE.. after I changed the plan, It happend4
