The changes requested for your plan were not done?
Ludovic D. #28593
Posts: 2 ✭✭
in My Mobile
Last month my plans didnt change and i spend all the month keep buying addons of 2go at a time and i ended up paying a shit tons, this month i had upgrade my plans with 10go and it was supposed to take place tonight but i just got a email telling me that the request to change my plans were not done? Am i gonna spend a month still paying expensive addons just to have lte? This is getting expensive and the whole point of me being with fizz is that it was cheap.
11
This sounds unusual. I've changed plans many times and never had issues.
What exactly did the email you received say? Surely it explains what happened or what can be done about it?4 -
Ludovic,
To change your Fizz mobile plan:
First, log to your Fizz account.
Click on: My plan (mobile)
Click on: Manage my plan
Click on: Adjust plan
Do the change of you need of your plan, then click on: Save the change.
You can also chat with the Fizz support (from 8h00 to 21h00) to get an answer about why the change of your plan didnt get applied this month.
To chat:
Click on:
https://fizz.ca/en/faq/how-do-i-change-my-mobile-plan
Click on the green chat bubble when you see it down to the right of the page.2 -
Good luck with this1
If you still haven't resolved your issue you should chat with the fizz support team.0
Hi.
Normally it's supposed to works, ask fizz directly there a problem right here.
Have a nice day0 -
You may want to contact Fizz technical support on chat to resolve this case.0
Contract fizz support for that1
So i contacted them on facebook yesterday and they told me they would put me throught with the technical team, wich for now has not been very helpful, still got no answer from them and i just moved in a new place so no wifi here, i got no data either wich is really great, i hope they fix it soon cause right now the only place i get wifi is outside of my workplace. Anyway i'll tell you all about any news so if theres any other person with the same problem, they'll know what to do.0
