Is it possible to install it in this building?
Fan L.
Fan L. Posts: 1 ✭✭
Is it possible to install it at this address?
  • Gabriel P. #28582
    Gabriel P. #28582 Posts: 6 ✭✭
    You didn’t post any adress you should update your post :).
  • Pascal L. 40582
    Pascal L. 40582 Posts: 649 ✭✭
    On Fizz website, start a plan for residential internet. After a few steps, it will ask you the address. Then it will confirm if that building can have internet connected.
    BTW, fizz uses Videotron service and cables (and installation technicians). If anyone in the building has or has had Videotron internet or tv, then it should be ok.
    MichelP Posts: 8,733 ✭✭
    Fan,
    Does Videotron's services are available into your building?
    If the answer is yes, you'll be able to get Fizz internet.
  • Olivier R. #3666
    Good luck my friend
