Why does my voicemail box only hold three messages, instead of 15 as advertised?
Inger W. #26615
Inger W. #26615 Posts: 1 ✭✭
I keep getting messages that my voicemailbox is full. Last time there were three messages in there. What is the fix for this?
    Mike Posts: 20,757 ✭✭
    Did you check if you have voicemail saved
  • Victoria C. #24523
    Victoria C. #24523 Posts: 367 ✭✭
    Not sure what the problem can be. What happens after 3 messages?
  • Stéphane L. 1007
    Stéphane L. 1007 Posts: 267 ✭✭
    You need to delete the old messages.
  • SuperFizzeur
    SuperFizzeur Posts: 3,777 ✭✭
    Hi Inger!
    Ask a fizz rep.
    Have a nice day :D
  • redhead
    redhead Posts: 818 ✭✭
    As others said, Fizz voicemail has a 15-message maximum capacity. Once this has been reached, people who are trying to reach you won’t be able to leave you a message. You may want to delete some messages to make room for new ones.
  • CaptFanta
    CaptFanta Posts: 271 ✭✭
    You should ask Fizz by Facebook here: https://www.facebook.com/fizzca/
  • AntonioMar
    AntonioMar Posts: 788 ✭✭
    If the problem is resolved, could you please close the question.
  • Aaron T. #7761
    Aaron T. #7761 Posts: 62 ✭✭
    Check for Saved messages. Otherwise you can contact customer service thru the green bubble that will appear in the lower right hand corner of this page
    https://fizz.ca/en/contact-us
    (note you must be logged in for this to work)
