Integration with home assistant
Sven D. #24176
Posts: 1 ✭✭
Many of us are automating our home with iot and different integration platforms. A famous open source one is Home assistant (https://www.home-assistant.io/). Could you offer a public API to get our account details (consumption mostly) so we could automate alerts, reporting... Etc
I used to do it with my previous mobile provider, please be innovative and tech savvy, you will attract all geeks!
12
If you are a geek probably you can build your own addons
At the moment is not available5 -
Hi Sven you seem to know a lot about tech! Hopefully your post get seen by the moderator and they might do it!7
Hey maybe they will listen to you and apply these changes6
