How to check internet speed in my location before purchase?
Yannick P. #25777
Yannick P. #25777 Posts: 3 ✭✭
Is it possible to check internet speeds in my location before buying this service? Last provider I had brought our plan down due to our location not being able to get a certain speed. I'm wondering if it's the same for all providers or just that particular one? Don't want to pay for extra speed I can't get
    MichelP Posts: 8,733 ✭✭
    Yannick,
    Normally, if you choose a speed for your plan, you will get that speed if your equipment is connected with an ethernet câble.
    For the wi-fi network, it can be less .
    Mike Posts: 20,759 ✭✭
    nowadays for cable connection the speed is not a problem.
    Moreover, Fizz is using a videotron cable which can deliver a 1Gbps
    Fizzy Posts: 10,935 ✭✭
    Hi Yannick,
    Was your last provider using cable technology or adsl (bell)?
    If it was adsl, you cannot compare. Fizz is using Videotron cable network.
    If Fizz lets you register the selected speed plan, then it should be available at your address.
    If you are not sure, then you can try selecting the same plan on any of the cable internet companies. If that speed is available, you will surely get it.
  • Yannick P. #25777
    Okay thanks for the replies.
  • Alexandre P. 40143
    Alexandre P. 40143 Posts: 204 ✭✭
    Sorry I don’t know how to help you
  • Liza K.
    Liza K. Posts: 1 ✭✭
    Not suer if this helps, but when looking for a phone plan with Fizz I googled "Fizz coverage" and it showed a map and wherever it was green that meant the service was LTE and all the other areas (red) the service would be 3G or poorer. This is to do with phone plans, could be different for internet...
  • SuperFizzeur
    SuperFizzeur Posts: 3,777 ✭✭
    Hi Yannick. Thanks for your fantastic question.
    You will get what you will pay for! On wi-fi it's normal you lose some speed, more far-away you are from router, less speed u get. But with ethernet cable (rj45) you will get full speed you can get, but it's depend on how devices is currently using your network.
    I think your old provider was using ASDL (internet over the phone line), Fizz use FTTN so the speed is constant.
    It's been a pleasure to assist you today. If you have any further questions don't hesitate to ask.
    Don't forget to mark this answer as the best answer! :)
  • SuperFizzeur
    Problem resolved?
  • Olivier R. #3666
    Thanks for the questions
  • AntonioMar
    AntonioMar Posts: 788 ✭✭
    If the problem is resolved, could you please close the question.
