When will anybody help internet up?
It had been 2days and fizz deleted my post about my internet issue. The connection is still off and they deleted my posts without explanation. The @ had blinking all day long but they ask me to check loosen screw
quan
quan
quan
Level
Hi Quan, you will have to contact the customer Service either on Facebook messenger (https://facebook.com/fizzca.) or Fizz Website by oppening this link (https://fizz.ca/fr/faq/comment-gerer-le-rendez-vous-avec-...) and simply scroll down until you see the Green Bubble, Click on it to start your Chat session with the customer service. Good Luck, they will be able to help you ! ! :)
Did you find this useful ?
No (0)
Yes (0)
quan
quan
quan
Level
Plz See my video
Alexandre
Alexandre
Alexandre
Level
2
1883 / 2000
Try to reboot your modem
Stanley
Stanley
Stanley
Level
3
2270 / 5000
Try rebooting the modem, otherwise the support is your best option.
sokarina
sokarina
sokarina
Level
2
1297 / 2000
Rebooting the modem could help. If it still doesn't work reach out to support
quan
quan
quan
Level
never mind, after all these days technical trouble in Longueuil, I've quit FIZZ internet,
plz just stop saying 'reboot your modem' or 'tighten screw' or 'reset factory', we user can do nothing with cable connections if its not stable then its totally technical issue
