The password provided is incorrect - ?doesn’t connect to to network. Help.
Karina B. #23016
Karina B. #23016 Posts: 1 ✭✭
The internet password provided does not connect. My phone settings says it’s an incorrect password for the network. HELP
    Mike Posts: 20,755 ✭✭
    The letters are sometimes confused with each other, for example L are similar with 1 ou i
  • Mo A.
    Mo A. Posts: 234 ✭✭
    @Karina,
    You can use a notepad and type the letters, it is confused make sure to key in the write letter
    Regards
    Mo
  • Ismail S. #23029
    Ismail S. #23029 Posts: 14 ✭✭
    its same pass than your wifi
