Not able to connect to 192.168.0.1 ?
Mico
Mico Posts: 3 ✭✭
I recently started with Fizz and after initial set-up have a hard time connecting to modem default address 192.168.0.1 as connection constantly times - out . And I need it badly to manage Wi-Fi On/Off mode.
Right now Wi-Fi and residential functions are turned off , modem is in the bridge mode. I do nor believe this should be the problem but need to resolve this problem ASAP. BTW what is 192.168.100.1 address for?
    Mike Posts: 20,775 ✭✭
    Usually the bridge mode is used if you have a router connected to the modem
    You should disable the bridge mode, enable the wifi and disable the band steering and the ATF
  • Qulbut
    Qulbut Posts: 3,474 ✭✭
    You need to contact the support
    CHAT
    Go to this page https://fizz.ca/en/contact-us, if you are not connect login
    The business hours: every day from 8 a.m. to 9 p.m. (EST).
    Wait 5 seconds for the bubble icon to appear at the bottom right of the browser and click on the icon to chat with support. Try a different browser if you have issues getting the bubble to appear.
    FACEBOOK
    P
    CONTACT FORM
  • M T. #12340
    M T. #12340 Posts: 605 ✭✭
    If you're in bridge mode then you should connect using 192.168.100.1.
