How many months car I carryover mobile data?
Nathaniel V.
Posts: 3 ✭✭
in My Mobile
Can unused data be carried over for unlimited time or is there a limit?
It's limited time, they last 90 days so after the first mont they are still available for 60 days.
Nobody likes losing something they’ve paid for. Which is exactly why we roll over your unused data at the end of each month. There’s nothing you need to do — your unused data is automatically rolled over to the next month at the end of each payment cycle.
Rolled over data lasts for the two following payment cycles, even if you change your plan. It’s always used before your monthly data. So if you have rolled over data, you’ll use it up first and then move onto the data in your regular plan.
Read this link about mobile data rollover
https://fizz.ca/en/rollover
And this one
https://fizz.ca/en/faq/what-is-rollover-and-how-does-it-work5
