Pay as you go?
Aaron S. #15485
Posts: 9 ✭✭
What is the pay as you go rate if I choose a basic plan with no included minutes and texts.
26
You have two option pay as you go
Appels
0,30 $ / min
Textos
0,05 $ / texto
Données
n.a
Or buy an addon
Appels/Textos
10,00 $
3,00 $
3,00 $
14 -
0.30$ per minute.9
Aaron,
It's less expensive if you buy an add-on for calls: 10.00$/300 minutes or 3.00$/60 minutes or 3.00$/ 200 textos.
or If you pay as you go: 0.30$/minute, 0.05$/texto.8 -
Hi Aaron, I believe that Mike gave you the full answer8
Add-ons are interesting because they last up to the end of the next cycle. Keep in mind though that you pay for both incoming and outgoing calls. Incoming texts are free so for me, 3 dollars for 200 textos every two cycles are more then enough.8
Mike has the best answer; time to select his reply as "best answer" and close this discussion.3
