I activated my Fizz SIM card yesterday, network shows Fizz and is working with my previous number - as expected. Now Videotron says that Fizz needs to send them a request for transferring the phone number, otherwise they will cancel it... Does it makes sense? The Phone is already working on the Fizz network with proper number.
Yes, however it is too late
The transfer should be asked during the activation, in theory you should close the Fizz account and repeat the procedure, however, you will loose the money.
Contact the support to see if they have a different way to do it.
Simon,
Try to contact Fizz for support for help.
Look to do a search in the community hub and wait 10 seconds, you are supposed to the green chat bubble dow to the right of the page.
Click on it when you see this green bubble et ask your question...
This is very particular situation, follow Mike's instructions
Hi Simon,
I've just checked your account and I can only see a Home Internet plan activated. I can also see a SIM card order but no transfer request. To be able to transfer your number form Videotron, first you'll need to place an order on your Fizz account by activating a mobile plan. You have more details on our FAQ: https://fizz.ca/en/faq/activate and on this one: https://fizz.ca/en/faq/activation-how-do-i-transfer-my-cu.... Once you place the order on your account, our system will process the transfer further.
If you have another account with an active transfer, or you need us to assist you further, I'm kindly asking you to contact us in private by chat or Facebook Messenger. Please check the info provided on the following links: https://fizz.ca/en/contact-us.
https://facebook.com/fizzca.
You can also open a Contact form from your account by going to My profile – Contact forms
Have a good one!
Radu
