Fizz Router always switches to channel 6
Alina R.
Alina R. Posts: 3 ✭✭
I have several neighbours whose 2.4GHz routers are set up on channel 6 and in our bedroom their routers' signal is as strong as mine thus I cannot stream to our chromecast device.
Through the fizz application I change the channel of my router to a different one (e.g. 9) and after reboot I see in WiFi analyzer app that it actually works on that channel. But next day it gets back to channel 6 while showing in the app that it's on channel 9.
It's super annoying, can you please fix this?
note: I know about 5GHz, but my device I am casting to cannot connect to 5GHz networks
  • Olivier R. #3666
    Oh my God !
  • Sebastien
    Sebastien Posts: 2,127 ✭✭
    If your device is a laptop you can get a USB 5g Wifi adapter, It might be actually be cheaper than to get an external router if you don't have.
