LTE not working
My LTE is not working. I have 2Gb left and nothing seems to work. It was working fine for 2 weeks and I did not move to another area, I still use it in the same places. I tried enabling the settings by sending the notification, I tried rebooting my phone, I tried setting up the APN thing manually, I tried updating my phone and nothing seems to work. My LTE is always on but it doesn't show on top of my phone and it is just not working at all, I have no internet connection from anywhere since yesterday. I need help
    Mike Posts: 20,757 ✭✭
    You must contact the support, since you are not the first one reporting this problem
    CHAT
    • Go to this page https://fizz.ca/en/faq/resolving-issues, if you are not connect login
    FACEBOOK
    CONTACT FORM
  • Nini G. #13860
    Personally I communicate with Fizz by messenger, that’s what works best for me. Good luck with this issue! It might be because of the storm?!
    MichelP Posts: 8,733 ✭✭
    Unfortunately,
    You must contact the Fizz support by chat.
    Just them can help you about thii issue.
    This service of chat is available from 8h00 to 21h00, each day.
    To do this without problem:
    First, connect you to your Fizz account.
    Then open a second window and types this adress:
    Wait to see the green bubble chat down to the right of the page.
    When you see it, click on it.
    Your chat session with Fizz begins.
  • Olivier R. #3666
    OMG I'm so sorry.
  • Sylvie D. #17174
    I have the same problem LTE is not showing on top and do not have any internet I have tried to contact the support but was not helpful
  • Olga P. #15146
    Olga P. #15146 Posts: 719 ✭✭
    everything work well for me.
  • Chris K. #7521
    Chris K. #7521 Posts: 486 ✭✭
    Try contacting support
  • Benoit D. #9220
    Benoit D. #9220 Posts: 284 ✭✭
    Works for me
  • Olga P. #15146
    So, did it works now?
  • WingsOfWisdom
    WingsOfWisdom Posts: 3 ✭✭
    After contacting the support it is now working perfectly.
    I don't know why it did that but here was my solution:
    I had to put "default,mms,supl" into the APN Type instead of "internet + mms"
