Regular data before upgrade data?
Am i reading this correctly or is the regular data used before the free upgrade data?
Did you find this useful ?
No (0)
Yes (0)
Lucas
Lucas
Lucas
Level
2
1766 / 2000
The data that has the closest expiration date will be used first. With the same expiration date, the free upgrade will be used first and then the “regular” data
Olivier
Olivier
Olivier
Level
5000 / 5000
Hello,. Maybe ypu Can contact the support.
it looks good
your regular data will always be the last to use since it will ber rolled over to the next month and then it will be used in chronological order
Is the upgrade an automatic one or you added it manually?
If you did it manually maybe the time it took to be applied you already started using your monthly data and now it seems as the upgrade will be used first. It happened to me before but it was with a perk and when people give you data they are place before your monthly data even if you've started using them.
If it is a automatic upgrade that is weird but now it seems as the upgrade will be used.
