Purchased a wrong addon
hjlecuyer
hjlecuyer Posts: 1 ✭✭
I was about to purchase Travel data and accidentally purchased data addon.. can you guys cancel this? I realized i bought a wrong one and i bought the correct one later.
    Mike Posts: 20,755 ✭✭
    We are users you must contact the support and ask to them
     Please ask them to remover your screenshot too
    CHAT
    • Go to this page https://fizz.ca/en/solutions
      , if you are not connect login
    FACEBOOK
    CONTACT FORM
  • Chris K. #7521
    Chris K. #7521 Posts: 486 ✭✭
    contact support, hopefully they will be able to reverse it.
  • Lucas A. #13141
    Lucas A. #13141 Posts: 354 ✭✭
    To be reimbursed, you’ll need to contact the support
  • Nini G. #13860
    Communicate with them by messenger, that’s what works best for me.I hope the will be able to help you.
  • Jimmy N. #14505
    Jimmy N. #14505 Posts: 620 ✭✭
    You need to contact them, it's the only way to get around something like this since it's in their system.
  • Thanh S.
    Thanh S. Posts: 360 ✭✭
    Please closw this
  • Gualberto
    Gualberto Posts: 340 ✭✭
    Have you been able to replace it ?
