What is the difference - level
Smilemars
Smilemars Posts: 156 ✭✭
Is there a difference between a profile leveling up and a Chat Community Leveling up?
It's a bit confusing. I see in the community with people with 5/5 geek level, but in other discussions I see 20 levels.
  • Abdul R. #3217
    Abdul R. #3217 Posts: 46 ✭✭
    Makes sense. If only there was a way to know how to get to the next level rather than just interacting with the community for who knows how long. Also do you get points for leveling up?
  • Olga P. #15146
    Olga P. #15146 Posts: 719 ✭✭
    @ Jimmy - yes, he has and answer and a picture for every question! What can i say: good job Mike! Keep going!
  • Jonathan T. #14361
    I think Mike should be renamed "The Fizz Grandmaster".
    Pretty sure he has answered 99% of the posts on this forum.
    Mike Posts: 20,759 ✭✭
    @Jonathan I hope that my answers are 99% correct, this is the most important part
  • Smilemars
    Thanks for all the responses!
  • Nini G. #13860
    Please choose the best answer to close the discussion.Happy New Year and may all the answers given helps you get to next levels in 2020!
