I bought a Brazil travel add-on before I left and now that I am in Brazil I can't get my phone to work. Data-roaming is activated on the phone. But it only connects to the internet if there is a free Wi-Fi connection, so I can't use any mobile data. Which means that I can't use Google maps to get around the country... How can I get my travel add-on mobile data to work?
I've got a Samsung Galaxy J1(6) phone, if that matters. Thanks for the help!
(I left this question a couple of minutes ago but mistakenly selected the Best Answer button before solving the problem. Duh!)
You should check your APN settings.
APN | Network Settings | Fizz
Fizz APN settings are:
APN: mobile.bm
MMSC: http://mms.mobile.bm
MMS proxy: mmsproxy.mobile.bm
MMS port: 80
APN type: default,mms,supl
Go to mobile networks settings, create a new APN and enter the information above.
Then you can delete all the others and let just this you created.
Restart your phone after.
Se precisar de comunicar em português, pode me enviar msg privada que eu o ajudo remotamente. Boa viagem!
Your phone must be compatible with the Band B3 or B7 for the LTE
try to enable the 3G
If you have the exact version of your J1 will be great to see wich band has
https://www.frequencycheck.com/carrier-compatibility/5QDvcKn/samsung-sm-j106b-ds-galaxy-j1-mini-prime-2016-duos/nextel-brazil
Did you put the carrier selection to automatic?
Did you already try to restart the phone, sometime helps
Hi Mike,
the exact model is SM-J120W. The carrier selection was previously on automatic, and the phone automatically chose Vivo as the carrier.
I am going to try Thiago's advice now and see if I can get it working.
Thanks so much for your help!
Thiago, it looks like your advice worked! Obrigado amigo!!!
