Should roaming be enabled?
The only potential downside is if you're in a marginal area--if you use more Fizz EXT that Fizz networks for 3 months in a row, you may be cut off from Fizz EXT networks. Some people have reported having this problem. It hasn't, however, been a problem for me personally to leave roaming on all the time.12
I personally leave roaming all the time. If Fizz cuts me off with a Canada Wide plan, i will cancel all and go to other operator.
I don't have love to cell providers. I just want a good price for a good service.11 -
I turn it on only when I am travelling or if there is a known on-going issue with the default network, but to each his own.
12 -
Hmm.. Not sure if there would be any downside to it but I personally don't keep roaming enabled. Don't see any point in doing that.12
As long as you dont' have any money in your wallet, I don't see any downside to having roaming turned on permenantly. If you have the right coverage, you will automatically be connected to the network as you travel. If you don't have coverage, you just won't get service. It's a prepaid service so you won't get extra charges.14
I agree, since fizz relies entirely on partner networks in order to provide service. Enabling roaming is imperative. The downsides are quite marginal12
