Loss of data connection through the day
Ramzie
Ramzie Posts: 4 ✭✭
I've been with Fizz for quite a few months now and I've never had any major issues. I am however noticing that for the last few weeks, multiple times throughout the day, as I go in my settings to turn on my cellular data, it says "no SIM"... My network does say Fizz however. I have an IPhone 7 Plus on the latest iOS, have restarted my device, still have data in my plan, etc. no improvement. This happens 5-10x a day which is quite inconvenient when I don't have access to wifi. Just inquiring if I'm the only one with this issue (then my phone would be the problem) or not ?
  • Legandir
    Legandir Posts: 607 ✭✭
    I dont have the same problem
  • Chris K. #7521
    Chris K. #7521 Posts: 486 ✭✭
    When this happens can you still make calls?
  • jeedey
    jeedey Posts: 83 ✭✭
    Never had any problem.
  • SittingRam
    SittingRam Posts: 320 ✭✭
    There is also the sad possibility that it might be the iphone. But I would bet on a defective sim
