Hi Samuel
Participation in the community hub (both English and French versions) is the quickest way to level up.
- Give up to 20 kudos per day (20 points).
- Answer...
Hey !
It's probably a bad question for you but, I would like to know if someone can do a list of the way to earn point and the reward for each level.
Thank you for the one...
to contact support:
Go to this page https://fizz.ca/en/contact-us, if you are not connected, login first.
•Their business hours are : 8 a.m. to 9 p.m. (EST). (Every Day)...
It's not the only way, but it's the best way. You get 3 points for asking and answering a question (5 for answering in less than 5 minutes), 20 points per day for kudos to other...
