I originally purchased before April 29, 2019.
I want to add data to my plan and make it 8 gigs.
Will I keep the stabilization price forever if I do this?
I read the stabilization post but I want to be sure before I do this.
Thanks
you can keep the intro price when you change your plan before 16 Oct.
According to this:
https://fizz.ca/en/node/2686
Good luck!
Since you bought after april 12 you will kepp your plan until january 1st.you can make any change until the 16th of october and you will keep the price until january 1st.
I hope this will help you.If you have any other question you can check the Faq of fizz there is a complet section on that with all the price , date to help you with this !
You will keep the stabilization price only if you activated before April 12 2019 and make your changes before October 16 2019.
You can adjust your plan in any fashion you want until next Wednesday (16th). You'll lose the stabilization price discount only if you make any modification after the 16th.
yes, until early 2020
Make your changes before october 16th to keep your price. If you activated first you plan before April 12th you will keep it as long as you don't change it. If you activated you first plan after April 12th then you will keep your price until the begining of 2020.
You didn't mention when your service started. You only said before April 29.
Yes, until early 2020 !!!!
Mohd was made best respondent
Leifuer was made best respondent
