Changing phones, do I need a new Sim card?
If you already have a IPhone, your actuel nano SIM card will work in your IPhone 11. Apple use the same size of SIM ( nano ) since the IPhone 5.7
You do not need to change it6
Congrats on the phone :-)6
No, you don't need a new SIM card.6
Sounds like you will enjoy having Fizz on new iPhone 11.
The SIM card will work on any unlocked phone that works with Fizz frequencies, and as long as the phone has not been reported stolen.
7 -
No, just put your existing SIM card into your new phone and you are ready to go.5
Yes it should work just fine. Make sure your phone is on the list working with Fizz though.5
I don't think you need one, since Fizz sim card is 3-in-1, it can be inserted into iPhone.3
No you can use the same sim1
