Upload speed change to 1.5 mbps on all plans?
I have just noticed that all plans upload speed appears to have changed to 1.5mbps instead of 10 mbps. How does this affect current customers and will this change be permanent?
  • Barry W. #11536
    The plan itself under my account information still shows 10 mbps... I cannot actually test right now since I am not home but this just seems a little odd to me
  • DIANA I.
    DIANA I. Posts: 19 ✭✭
    it's a mistake,
    try to refresh your browser
    or use another browser
  • rleema
    rleema Posts: 6 ✭✭
    I don't see that on my browser, I see the normal 10 Mbps
  • J D. #792
    J D. #792 Posts: 316 ✭✭
    it seems to be another typo error happening in the last 2 days...My speedtest still showing the correct speed no problem.
    Whizz Posts: 19,191 admin
    Hello all,
    We are very sorry for the inconvenience. There was only a tiny glitch in our display. Everything is back to normal now!
    -Bogdan
