I plug everything in . all the lights match but my onternet is not working ?
All the lights match I poured everything in I put on the password. Ant or tells me can not connect to the Wi-Fi ?
    Mike Posts: 20,755 ✭✭
    Try to connect the cable or check your password, sometime letters are exchanged for numbers, zero for O etc
    Fizzy Posts: 10,930 ✭✭
    Did you already read this?
    https://fizz.ca/en/faq/how-install-my-wi-fi-modem
    Find the network name (Default Wi-Fi Network) and password (Default Key) printed on the back of your Wi-Fi modem.
    COMMENT4
    If the network name (Default Wi-Fi Network) does not appear in the list of available networks on a Wi-Fi enabled device, it means your Wi-Fi modem's update is not complete.
    Pay close attention to characters that are similar, such as O and 0, as well as I and 1.
  • Jaquesdoo
    Jaquesdoo Posts: 119 ✭✭
    is that to reset to the factory ? and use the default setting ?
    Whizz Posts: 19,198 admin
    Hi Nicole,
    Can you please tell us if the issue is still there?
    Fizzy got a pretty good advice.
    -Bogdan
  • Olivier R. #3666
    are you using windoes 10 ?
  • Chris K. #7521
    Chris K. #7521 Posts: 486 ✭✭
    Try plugging with a cable
