Why is the modem interface unusable?
I set the modem in bridge mode, change my mind, reset the modem with the reset button, unplug it for 10 seconds. Now, when i try to connect to 192.168.100.1 (with a wire), the webpage are extremly slow and keep timing out. The wifi is also not working anymore. How can I fix this problem?
    Mike Posts: 20,759 ✭✭
    The default is not 192.168.0.1?
  • Jonathan B. 29647
    Maybe. In my case, 192.168.0.1 never work (ERR_CONNECTION_TIMED_OUT) , 192.168.100.1 work very slowly and it's nearly impossible to accomplish any task before it's time out.
    Fizzy Posts: 10,932 ✭✭
    If you did proper reset of the modem, the correct ip address is 192.168.0.1
    If you want to re-enable the Wi-Fi capability of your Fizz Wi-Fi modem, you'll need to reset it to its factory settings by holding down the reset button on the back of the device for ten (10) seconds.
  • M T. #338
    M T. #338 Posts: 2,934 ✭✭
    192.168.0.1 never worked for you in modem/router mode probably because you have a fixed IP address and your default gateway is <> 192.168.0.1
  • Gates
    Gates Posts: 835 ✭✭
    In order to help the Fizz community evolve with your question, do not forget to identify the best answer given to you by members of this discussion group using the Make Best Answer button.
  • Chris K. #7521
    Chris K. #7521 Posts: 486 ✭✭
    When you press the factory reset button, make sure to hold it down for awhile (10 seconds) otherwise it won't work.
  • Chris K. #7521
    Did you fix the issue?
