Just reporting not able to receive or make phone calls on the Fizz network, to make or receive I have to switch to an EXT network
if this happen again, you can check on website, they will list the current network statues
Had service switching today and yesterday from EXT to NO SERVICE
Thank you for sharing and reporting it here.
As you probably know, we are in stabilization period so these things can happen.
You can try turning airplane mode on, waiting 30 seconds, and turning airplane mode off.
If that does not work, try turning the phone off then back on.
Last resort would be to contact Fizz via chat or Facebook messenger.
Try turning off your phone then back on, but it’s most probably due to the stabilization period. It happened to me twice last April.
In order to help the Fizz community evolve with your question, do not forget to identify the best answer given to you by members of this discussion group using the Make Best Answer button.
Same thing happened again today, looking like a pattern... just mentioning I’m in K1C area...
