I want to buy a Fizz SIM card but I’m not sure if it will work in Moncton (Nb) my friend can ship it to me from Montreal but once it’s here I don’t know font it will work or not. Can anyone help
You can use Fizz temporarily out of the subscription area (like when you are vacationing) but it is not meant for long term use on partner networks.
The expanded coverage zone is for our mobile members who travel in specific regions not covered by the Fizz network (Subscription area). It is intended for occasional coverage, and applies to Quebec, Canada and USA.
The majority of your usage (calls, texts and data) must be done on the Fizz network (Subscription area).
We reserve the right to block access to all of your Fizz mobile services if your mobile services are used primarily on partner networks (Fizz EXT) for 3 consecutive payment cycles.
Use our coverage map to check that you are using your phone in a zone covered by the Fizz network:
Visit our network coverage map to check the subscription area.
(On the coverage map the subscription area is Fizz network, the coverage area is patner networks)
Check the name of the network indicated on your phone. If 'Fizz EXT' or if it does not say Fizz, you are on one of our partner networks and your usage will be considered extended coverage. You can adjust your phone’s settings to limit this usage by deactivating roaming on our partner networks.
If you do not have the choice and you are geographically obliged to use the majority of your usage on our partner networks beyond the tolerated limits, we advise you to subscribe with the service provider who offers coverage in this area.
There is coverage supplied by partners. But you can't have a SIM card shipped to this location as it isn't a subscription area. Use the interactive map in the link below.
You cannot use fizz outside the subscription area for more than 3 consecutive payments cycles, since it only meant for people using under the subscription area, therefore, I am sorry but you cannot
I believe that you got your answer, please close the post by clicking on the button "Make this a best answer."
