Unanswered question
My mobile internet works fine and everything, but i don't have signals ? Like i can't make calls or send messages but my LTE/4G works fine
Which phone are you using? Have you checked that it is compatible with Fizz network
Have you tried connecting to 3G network instead of LTE?
Have you checked your Fizz account? Does the plan you have now include calls and texting?
If account checks out okay, have you tried rebooting phone?
Yes my phone is compatible ( Samsung galaxy s9 ), and yes my plan includes unlimited texts and messages and 10 GO of internet. I did reboot, open and put my sim card back, but still my messages and texts doesn't work..
If you just activate your sim then it may take a while until all services are available
In order to help the Fizz community evolve with your question, do not forget to identify the best answer given to you by members of this discussion group using the Best Answer? button under the answer you deem to be the best.
Even though your phone is compatiable, have you tried testing your SIM card on another phone?
If problem persists, you should contact Fizz support.
You can send Fizz a message by facebook https://facebook.com/fizzca
Or you can use Fizz chat. Make sure that:
