This is 1Gb perk, therefore, I will give to someone without data in his plan
Very generous of you Mike!
Thanks, Data still available? :)
I am interested if still available thanks
@Sarina do you have a data plan in your mobile?
you need to have data plan to be able to receive data gifts
if you have anything left i am short this month on data
Thanks
@Takion: then if you do not have a data plan, contact me and I will send it to you
no I do not have a data plan
@sarina: Using the PM send me your phone number or email associated to fizz
nothing showed up yet are you certain that someone with out data plan can receive data gifts
That one yes, since it was the 2Gb from the down, Fizz confirmed the reception
probably takes time for the transfer
Thanks
