Hey guys! Newbie here just pulled the trigger on the home internet services for 30mbps at $40. While scheduling the installation I was prompted with a free installation or a $30 VIP set up. I was wondering how difficult is the installation process if I were to do it myself? Could it be worth just dropping the extra cash for less hassle?
You pay 30$ to have a tech unbix your router/midem and plus 2-3 wires in it then setup your wifi via a webpage procedure that is described on the cardboard box... so if you are a bit tech savy then no, it's not worth it imo.
The difference is the router configuration, should be straight forward if you already did.
If you still waiting to make the command, here my referral code K61CD in order to have 25$
if you are able you follow instruction and pretty comfortable with windows, I think you can save the 30$ VIP setup. If you currently use cable internet, it's even easier. Basically, without VIP service, the tech will come to your house and setup/verify the cable line for you and drop off the modem. All you need to do it's follow the instruction that comes with the modem. It's really straight forward.
