I I lost my pin of my voice mail account.
Hi Sandra,
Here are the instructions to reset your pin. By the way You should edit your post and remove your phone number from it.
Modifiy your access code (PIN) to access your voicemail online, directly from your Fizz account.
(Under: My plans > Manage my plan > Advanced parameters > PIN to access my voicemail)
IMPORTANT: Unsafe sequences will be refused (for example : 1234, 8888, etc.).
Modify your access code (PIN) to access your voicemail online, directly from your Fizz account.
Fizz voicemail FAQs can be found here
https://fizz.ca/en/faq/how-do-i-access-my-voicemail
https://fizz.ca/en/faq/how-does-my-voicemail-work
Edit: Nice reply @Sami
You can reset it via the fizz profile page. Good luck
I signalled the post in order to have the phone number removed.
This is a public forum
samisheikh was made best respondent
Mike answered
Simon answered
Fizzy answered
samisheikh answered
Enfants123 posted a new question
