for the past two weeks i have been havingt his issue
when i call someone it shows it as a private number. Howver poeple can call me with no trouble
DOes anyone else have a similar problem, or know of how i can fix this ?
If you have an IPhone,
-Go to settings
-Then select phone
-Then select Show my caller ID
And make its selected
Check the configuration of your phone
In your phone setting, you checked "hide my caller id", uncheck it.
thna you @simon it works !
