Is it possible to only do prepaid and not have a plan?
Dan S. #6463
Dan S. #6463 Posts: 1 ✭✭
I would like to know, is it necessary to buy a plan? Can I just do add ons or prepaid?
    Mike Posts: 20,801 ✭✭
    No, is not possible
  • Allison W.
    Allison W. Posts: 1,272 ✭✭
    Yes, but the minimum monthly charge, with nothing included, is currently $7.20 +911 fee + taxes for quebec and $9 for canada. Then you have to add in the cost of add ons, or pay as you go money into your Fizz wallet. This price will increase by 30% when their stabilisation period ends. It isn't worth it compared to other pay as you go companies.
    https://fizz.ca/en/mobile-plan?CVRG=108&DATA=231&PLAN=1&SMS=91&VOICE=232
  • GOAT
    GOAT Posts: 227 ✭✭
    It honestly makes no sense to use Fizz this way. The plan prices are great, but add-ons are relatively expensive. If you insist on pay-as-you-go, Fizz probably isn't your best option.
    Fizzy Posts: 10,975 ✭✭
    Fizz is a Prepaid mobile service. The minimum monthly plan costs $7.20+taxes, for which calls, texting and data are Pay-As-You-Go services that will cost extra.
    As the name implies, there are Add-Ons. And you need to have a plan in order to purchase Add-Ons
