Having issues with your mobile network tonight. Signal very low or not available. Says Emergency Calls Only
Bill, your problem seems to be fixed. So you can select the best answer to close this thread.
In case of service interruption, you can always look at this page first https://fizz.ca/en/faq/status-services
Then you can ask the forum for any assistance;
Then you can go to Fizz support team via Messenger or Contact form.
Restart your phone, it should come back
Seems like a temporary network issue on Fizz's side if it's already resolved.
Late in last night with the same issue, but it works now.
There was a network-wide issue. Should be all good this morning.
